13 years agoring oscillator as a clock
Hi, I am having a problem using 2 ring oscillators as 2 different clocks to 2 8-bit counters. When I use them separately they are working. But when I combine the two circuits in one design the out...
13 years agoYou are targeting generating clock from logic delays. While this is theoretically possible but practically FPGAs cannot generate useful clock like signals based on delays.
The practical approach is to to provide time base for fpga(reference clock) then either multiply/divide it in fpga PLLs or divide it in logic using simple counters or ring counters. ring counters are preferred for small counters as they are built from back to back registers and so pass timing readily. Thus your code will look like this:
process(reset,clk)
begin
if reset = '1' then
node1 <= "00001";
elsif rising_edge(clk) then
node1 <= node1(4 downto 0) & node1(4);
end if;
end process;
clk_slow_sig <= node1(1);
