11 years agoRGMII RX Clock on a non-clock pin (normal pin)
Hi there, I have some timing problems with my rgmii rx interface. Due to a design error the rx clock is not connect to an dedicated clock pin. This error results a high delay on clock path and ...
11 years ago --- Quote Start --- Hi there, Is there anyway to compensate the error aftwards? (through an IP-Core or an assignment maybe?) --- Quote End --- Hi, I think this is not recommended way to implement it, but in principle You could try to use logic resources for the clock routing towards the DDRIO-cell. In this case it could be the shortest path, and quite well matched with data.. e.g. set_instance_assignment -name GLOBAL_SIGNAL OFF -to rx_clk Then you should instantiate clkctrl -block to provide optimal clock for the rest of the domain.. Small design could work without clkctrl (at least design with only Altera TSE did meet timings without clkctrl). A bigger design that I tried failed without clkctrl,.. With Best Regards, Jarkko PS. This same feature can be found from Cyclone V GT FPGA Development Kit schematics :)
