11 years agoRGMII RX Clock on a non-clock pin (normal pin)
Hi there, I have some timing problems with my rgmii rx interface. Due to a design error the rx clock is not connect to an dedicated clock pin. This error results a high delay on clock path and ...
11 years ago --- Quote Start --- Is there anyway to compensate the error aftwards? (through an IP-Core or an assignment maybe?) --- Quote End --- This is why you should place-and-route a design before the board is built :) The two work-arounds I can think of are; 1. Add a rework wire to route the signal to a clock pin. 2. Use a PLL to phase-shift the clock so that you can meet timing. Option (2) "sounds good", but since you have used a non-dedicated clock pin, you'll probably get warnings about that too. However, it might be enough for you to confirm that the RGMII interface works "well enough" so that you can move on and find any other hardware errors. The long-term fix would require the board design be corrected, sorry. Cheers, Dave
