16 years agoReverse engineering a Cyclone III system?
I have a design that runs on a Cyclone III Starter Board. This board uses active parallel configuration and an Intel 128P30-type parallel flash memory. In my design the flash also contains Nios II ...
16 years agoi once did a test setting a single M4K/M9K to all 0s and then all 1s and did a diff on the resulting SOFs . the results were different enough that it looked too tedious to reverse engineer. i suppose its possible, but you'd think it would be faster to actually develop the IP yourself.
