10 years agoResize function not working
I'm trying to use the resize function in order to convert a signed 12 bit value to a 31 bit value. But whenever I'm using the resize function the output value is 0. But when I'm manually converting i...
10 years ago --- Quote Start --- data_in : IN std_logic_vector(11 downto 0); ( including the signed bit ) -- converting to 31 bit signal l_data_in : signed(30 downto 0); l_data_in <= resize(signed(data_in),31); I was using the same thing that you posted, but all my converted values were 0 when I checked in signaltap --- Quote End --- I can assume your problem of zeros is not related to resize function failure. resize is simple function that extends the sign bit.
