16 years agoreset input signal
Hi. I heard that the reset signal is better in active low. Is it true? If it is true may i know why? thanks
16 years ago --- Quote Start --- http://www.xilinx.com/support/documentation/white_papers/wp248.pdf "Active-High control signals should be used wherever possible in the HDL code or instantiated components" --- Quote End --- Interesting. But this applies to Xilinx devices, and only to Virtex-5 and later ones. All Altera FPGA families have a programmable inversion for each one of the control signals. And it seems this was true for Xilinx as well, until Virtex-4. For some reason Xilinx decided to remove the programmable inversion feature on later devices.
