16 years agoreset input signal
Hi. I heard that the reset signal is better in active low. Is it true? If it is true may i know why? thanks
16 years agoHello,
I am not sure about this in altera, but Xilinx suggest for Virtex 6 to use active low control signals because the FF of their Logic Elements have active low signals, so if you use Active High control signal, your signal must cross one LUT to be inverted before connected, it depends of the architecture of the FPGA. Good Luck. DABG
