nirsap
7 years agoRemove SignalTap QSF auto insertion lines "set_instance_assignments -name CONNECT_TO_SLD..."
Hi, Quartus 18.1 Prime I'm using SignalTap at the debugging. Is it possible to disable the Quartus auto writing signaltap assignements into the QSF file? I mean to the following lines: "set_i...
sstrell
7 years agoIf you want Signal Tap to work, then the assignment is needed. If you want to remove the line, disable Signal Tap in the project settings before adding the project to your version control system.
#iwork4intel
