14 years agoRemote update with EPCS128
Hello, Guys. I have a Stratix II EP2S90 design that uses an EPCS128 device in AS mode for remote system update. The new Application image is got from the DSP (DM6437). And altasmi_parallel is used...
14 years agoWhen I bump into these kind of problems with bit order and such I always resolve it in the same manner.
1. Program the EPCS128 through the quartus programmer like normal. Then read it back into a file. 2. Program the EPCS128 through your remote update procedure using the .rbf file from the same build. Read back that image using the quartus programmer. 3. Compare 1 and 2. They should read back identical. /Boris
