BCrowell
2 years agoRemote Update of Cyclone 10
In my application I would like to have an application configuration that is normally used on every power cycle and a golden default configuration that is used only when the application config fails t...
BCrowell
2 years agoFakhrul,
I am ok with my golden config being the factory image, I just want to directly load the application config and only load the factory config if that fails. It sounds like that can't be done and the system needs to load the factory config first before switching to the application config in order to properly fall back in the event of an error. I don't necessarily see the advantage of this process but I haven't used Intel/Altera FPGAs in many years, so I just may be missing something. Is there something that the factory config does that differentiates it from an application config besides initiating the loading of an application config?
Brad
