Remote update hex file in UFM MAX10 due to UART
Yes, please take a look at the user guide attached. Inside has the information regarding to the design to enable remote update.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf
- johny74015 years ago
Hi YuanLi_S_Intel!
I know this AppNote, it has a description about CFM upgrading and HAL-soft using, but I need UFM upgrading and NOT HAL-soft using, as I had written earlier. I want to compose a verilog's module which has to receive data (.rpd file and swap bits in each byte) and handle with on_chip_flash IP.
Because I am not using QSPI flash in my MAX10 project. My code will be stored in UFM of MAX10. Also "scanf" function is more expansive of flash memory, therefore I want to upgrade my code (UFM) due to UART and verilog's module.
In last post you answered that I can handle with on_chip_flash IP by help of verilog's module. Can you point me where is it described or do you have some examples of it?
