fpgaSoft
2 years agoRemote update for Cyclone 10GX
I am writing a bootloader programme using the Intel Remote update IP on a cyclone 10GX. The Remote update block is part of a NIOS II system and is setup using platform designer. The factory image i...
NurAiman_M_Intel
2 years agoHi,
May I know the sequence of observation of ru_configuration_mode. Is it observed after reconfiguration or prior to reconfiguration?
Aiman
fpgaSoft
2 years agoHi,
The factory image tells the RU block to start the application image.
Then when the application image starts up, the first thing it does is read the ru_configuration_mode .
I hope that helps clarify things
Best regards
