fpgaSoft
2 years agoRemote update for Cyclone 10GX
I am writing a bootloader programme using the Intel Remote update IP on a cyclone 10GX. The Remote update block is part of a NIOS II system and is setup using platform designer. The factory image i...
NurAiman_M_Intel
2 years agoHi,
May I know the sequence of observation of ru_configuration_mode. Is it observed after reconfiguration or prior to reconfiguration?
Aiman
- fpgaSoft2 years ago
The factory image tells the RU block to start the application image.
Then when the application image starts up, the first thing it does is read the ru_configuration_mode .
I hope that helps clarify things
Best regards
