16 years agoRemote update EPCS file format?(rpd or rbf)
I have a Cyclone III EP3C5 design that uses an EPCS4 device in AS mode for remote system update. my question: what file format am I supposed to use when downloading a new application configuration into the EPCS16?.rpd or .rbf or else?
Please help. Thanks a lot in advance13 Replies
If you are using srunner software then rpd is the obvious choice. But I wrote my own drivers from scratch and just used the rbf file because it was lying around on the disk. And yes, I had to bit reverse the bytes for use by the altera altasmi_parallel megafunction. Watch that one!
Nick - Altera_Forum
i am afraid i have to disagree. RPD is the correct format. it is already bit reversed.
.rbf
But make sure you use the correct bit order. In some applications you need to flip the bits like this: out_byte[7] <= inByte[0]; out_byte[6] <= inByte[1]; out_byte[5] <= inByte[2]; out_byte[4] <= inByte[3]; out_byte[3] <= inByte[4]; out_byte[2] <= inByte[5]; out_byte[1] <= inByte[6]; out_byte[0] <= inByte[7];
