16 years agoRemote update EPCS file format?(rpd or rbf)
I have a Cyclone III EP3C5 design that uses an EPCS4 device in AS mode for remote system update. my question: what file format am I supposed to use when downloading a new application configuration i...
16 years agoIf you are using srunner software then rpd is the obvious choice. But I wrote my own drivers from scratch and just used the rbf file because it was lying around on the disk. And yes, I had to bit reverse the bytes for use by the altera altasmi_parallel megafunction. Watch that one!
Nick
