15 years agoRemote update EPCS file format?(rpd or rbf)
I have a Cyclone III EP3C5 design that uses an EPCS4 device in AS mode for remote system update. my question: what file format am I supposed to use when downloading a new application configuration into the EPCS16?.rpd or .rbf or else?
Please help. Thanks a lot in advance13 Replies
I use quartus 9.0,same as you,i just see symbols ,that‘s doesn't matter
Then what did you write into EPCS? How did you applied bit-reversal to each byte before writing into EPCS? You mentioned that you used I2C, so you must had some byte to transfer. You can't transfer symbols. I think you might be reading the file in some way and that's why you didn't bother about the contents of the file. How did you do that?
i think you make this too complicated,CPU deliver the .rbf file without any change,
i did bit-reversal in fpga as foll assign d_to_E[0] = data_to_EPCS[7]; assign d_to_E[1] = data_to_EPCS[6]; assign d_to_E[2] = data_to_EPCS[5]; assign d_to_E[3] = data_to_EPCS[4]; assign d_to_E[4] = data_to_EPCS[3]; assign d_to_E[5] = data_to_EPCS[2]; assign d_to_E[6] = data_to_EPCS[1]; assign d_to_E[7] = data_to_EPCS[0];
