17 years agoRemote update EPCS file format?
I have a Cyclone III EP3C5 design that uses an EPCS16 device in AS mode for configuration. I have successfully implemented the ALTREMOTE_UPDATE function as well as a function to load a new applicati...
8 years agoHi,
Because I use the third-party flash (S25FL064), the quartus programmer cannot recognize the chip. So I use nios2-flash-programmer to download .flash files. Will this cause any reconfig problem? If I put the user image at 0x000000, the device boots well. And if I put the same image at 0x200000, the reconfig fails. I read out the data in the flash device by using NIOS2-Eclipse in debug mod. It seems everything is same. No ideas for this issue. hdai
