17 years agoRemote update EPCS file format?
I have a Cyclone III EP3C5 design that uses an EPCS16 device in AS mode for configuration. I have successfully implemented the ALTREMOTE_UPDATE function as well as a function to load a new applicati...
13 years ago --- Quote Start --- The EPCS is programmed correctly, which I verified by reading the contents of it using the Examine feature of the Quartus-II programming tool. --- Quote End --- How did you read the contents of EPCS? I couldn't find the Examine feature, you have mentioned, in Quartus II programmer.
