Remote system update for arria10 FPGA
we are using Arria 10 FPGA DEVICE "10AX057N2F40E2SG", we needed to use Remote system update feature for our custom board.
From the intel design store, there are two reference design modules.
But from rocketboards website it is stated as
https://www.rocketboards.org/foswiki/Documentation/RemoteSystemUpdateCompatibility
"The Remote System Update (RSU) is a feature available for Stratix 10 and Agilex FPGA devices"
please Clarify whether Arria10 will support or NO!
Rajesh
- tehjingy_Altera
Hi Rajesh
The files are up now in the case comment previously.
Could you try check it out again?
Jingyang, Teh
- Rk_Athram
Hi Jingyang, Teh
I think you missed files attachment/ link.
Rajesh
- tehjingy_Altera
Hi Rajeesh
Sorry for the late reply.
I just tried out the example design and found that the files in the example design is not working.
I will work with the owner on this.
Mean while you could try out the files attached.
I have created it base on the user guide of the example.
Please refer to the .map for the start and end address.
jingyang, Teh
- Rk_Athram
Hi Jingyang, Teh
Yes
Is example design working for you!Regards,
Rajesh
- tehjingy_Altera
Hi Rajesh
Did you flash the initial image to set up the image layout for the Factory and the Application Image?
Jingyang, Teh
- Rk_Athram
Hi Jingyang, Teh
Yes, we are maintaining factory image, by programming ru.jic.
Rajesh
- tehjingy_Altera
Hi Rajesh
Before you start the steps of flashing the application image did you flash the ru.jic image to setup the flash layout?
Jingyang, Teh
- Rk_Athram
Hi Jingyang, Teh
Thank you for your efforts.Please update me once you receive the solution/any modification required in the example design.
Rajesh
- tehjingy_Altera
Hi
Sorry I have no update for this week.
I am still waiting for a reply from our internal engineering team.
Jingyang, Teh
- Rk_Athram
Hi Jingyang, Teh
Please share the results after the tests, why the design is NOT giving expected output.Regards,
Rajesh
