13 years agorelative path in a do file
hello
i am a beginner in modelsim i want to use relative path in do file but it doesn't work my os is windows xp my relative path is : vcom -work Work_Project ../../SRC/A_Interface.vhd error: Failed to open design unit file "../../SRC/A_Interface.vhd" in read mode. how can i do this? thanks alot.11 Replies
--- Quote Start --- when checked the Modelsim reference manual, i found the following commands for the question i posted config list -strobeperiod {100 ns} -strobestart {0 ns} -usestrobe 1 add list -notrigger clk -window mylist a b c d write list mylist.save; I will check if this can solve my issue ,Thanks --- Quote End --- Dear all With above commands i am able to create the list file But problem came when trying to generate multiple list files I am able to create two list files but the data will only be updated in only one list file The window generated with view list -new highlighted below The commands i used are as follows : config list -strobeperiod {100 ns} -strobestart {0 ns} -usestrobe 1 set wind1 [view list -title wind1] add list -notrigger -label a -window $wind1 simulationpath set wind2 [view list -new -title wind2] add list -notrigger -label b -window $wind2 simulation path run 50 us write list -window $wind1 wind1.list write list -window $wind2 wind2.list Please let me know the reason behind why only one list file is updated Thanks in advance for all your support
