13 years agorelative path in a do file
hello
i am a beginner in modelsim i want to use relative path in do file but it doesn't work my os is windows xp my relative path is : vcom -work Work_Project ../../SRC/A_Interface.vhd error: Failed to open design unit file "../../SRC/A_Interface.vhd" in read mode. how can i do this? thanks alot.11 Replies
--- Quote Start --- when checked the Modelsim reference manual, i found the following commands for the question i posted config list -strobeperiod {100 ns} -strobestart {0 ns} -usestrobe 1 add list -notrigger clk -window mylist a b c d write list mylist.save; I will check if this can solve my issue ,Thanks --- Quote End --- Dear all With above commands i am able to create the list file But problem came when trying to generate multiple list files I am able to create two list files but the data will only be updated in only one list file The window generated with view list -new highlighted below The commands i used are as follows : config list -strobeperiod {100 ns} -strobestart {0 ns} -usestrobe 1 set wind1 [view list -title wind1] add list -notrigger -label a -window $wind1 simulationpath set wind2 [view list -new -title wind2] add list -notrigger -label b -window $wind2 simulation path run 50 us write list -window $wind1 wind1.list write list -window $wind2 wind2.list Please let me know the reason behind why only one list file is updated Thanks in advance for all your support - Altera_Forum
i found the following commands for the question i posted config list -strobeperiod {100 ns} -strobestart {0 ns} -usestrobe 1 add list -notrigger clk -window mylist a b c d write list mylist.save; I will check if this can solve my issue ,Thanks - Altera_Forum
Dear all
i would like to know the script for creating the list file Presently i am adding the list signals manually by dragging and dropping from waveform Also when i drag and drop the signals to list file it will initially shows me the signals in default mode (whenever signal transition) I would like to have signals added to list file on each clock transition Please suggest me how to create the list.lst using the script or any good reference Thanks in advance - Altera_Forum
Here, try these two scripts:
# test1.do# # Example to show relative sourcing of scripts. # Path to this script set path ]] puts "Hello from test1" source $path/test2.do
The output from Modelsim is:# test2.do puts "Hello from test2"
The script was sourced from an arbitrary location. Cheers, DaveModelsim> source c:/temp/test1.do# Hello from test1# Hello from test2 - Altera_Forum
easiest thing to do is have a "cd /proper_directory" as the first line in the .do file.
you cant (afaik) - you need to change directory to where the .do file is located.
--- Quote Start --- to change the drive, you type: cd c: to change directory cd /directoryA/directoryB the first slash essentially means "root" and on windows that means whatever drive you're currently on. --- Quote End --- the question is "how can i obtain path of the .do file that is running?" i need a command to tell me what is the full path. - Altera_Forum
cd c: to change directory cd /directoryA/directoryB the first slash essentially means "root" and on windows that means whatever drive you're currently on. - Altera_Forum
thanks for your answer
according to your answer, i tried to get absolute path of my script by using "file dirname" command but it give me relative path. i want to able my script to work on any machine. so i need to inform absolute path of script. please help me what i suppose to do. thanks alot. - Altera_Forum
you can type commands into the modelsim command line, and they mostly match linux command. Use "pwd" to see where the current modelsim directory is.
