13 years agorelative path in a do file
hello i am a beginner in modelsim i want to use relative path in do file but it doesn't work my os is windows xp my relative path is : vcom -work Work_Project ../../SRC/A_Interface.vhd ...
13 years agoDear all
i would like to know the script for creating the list file Presently i am adding the list signals manually by dragging and dropping from waveform Also when i drag and drop the signals to list file it will initially shows me the signals in default mode (whenever signal transition) I would like to have signals added to list file on each clock transition Please suggest me how to create the list.lst using the script or any good reference Thanks in advance
