regarding my top file...
module NIOSII_DATA_FLASH(
iCLK_50, // 50 MHz
pll_c0_out,
pll_c1_out,
iKEY,
iSW,
oLEDG,
oLEDR,
oHEX0_D,
oHEX1_D,
oHEX2_D,
oHEX3_D,
oHEX4_D,
oHEX5_D,
oHEX6_D,
oHEX7_D,
LCD_D,
oLCD_ON,
oLCD_BLON,
oLCD_RW,
oLCD_EN,
oLCD_RS,
oUART_TXD,
iUART_RXD,
DRAM_DQ, // SDRAM Data bus 32 Bits
oDRAM0_A, // SDRAM0 Address bus 12 Bits
oDRAM1_A, // SDRAM1 Address bus 12 Bits
oDRAM0_LDQM0,
oDRAM1_LDQM0,
oDRAM0_UDQM1,
oDRAM1_UDQM1,
oDRAM0_WE_N,
oDRAM1_WE_N, // SDRAM1 Write Enable
oDRAM0_CAS_N, // SDRAM0 Column Address Strobe
oDRAM1_CAS_N, // SDRAM1 Column Address Strobe
oDRAM0_RAS_N, // SDRAM0 Row Address Strobe
oDRAM1_RAS_N, // SDRAM1 Row Address Strobe
oDRAM0_CS_N, // SDRAM0 Chip Select
oDRAM1_CS_N, // SDRAM1 Chip Select
oDRAM0_BA, // SDRAM0 Bank Address
oDRAM1_BA, // SDRAM1 Bank Address
oDRAM0_CLK, // SDRAM0 Clock
oDRAM1_CLK, // SDRAM0 Clock
oDRAM0_CKE, // SDRAM0 Clock Enable
oDRAM1_CKE, // SDRAM1 Clock Enable
FLASH_DQ, // FLASH Data bus 15 Bits (0 to 14)
FLASH_DQ15_AM1, // FLASH Data bus Bit 15 or Address A-1
oFLASH_A, // FLASH Address bus 26 Bits
oFLASH_WE_N, // FLASH Write Enable
oFLASH_RST_N, // FLASH Reset
oFLASH_WP_N, // FLASH Write Protect /Programming Acceleration
iFLASH_RY_N, // FLASH Ready/Busy output
oFLASH_BYTE_N, // FLASH Byte/Word Mode Configuration
oFLASH_OE_N, // FLASH Output Enable
oFLASH_CE_N, // FLASH Chip Enable
input iCLK_50;
output pll_c0_out;
output pll_c1_out;
input [3:0] iKEY;
input [17:0] iSW;
output [8:0] oLEDG;
output [17:0] oLEDR;
output [6:0] oHEX0_D;
output [6:0] oHEX1_D;
output [6:0] oHEX2_D;
output [6:0] oHEX3_D;
output [6:0] oHEX4_D;
output [6:0] oHEX5_D;
output [6:0] oHEX6_D;
output [6:0] oHEX7_D;
inout [7:0] LCD_D;
output oLCD_ON;
output oLCD_BLON;
output oLCD_RW;
output oLCD_EN;
output oLCD_RS;
output oUART_TXD;
input iUART_RXD;
inout [31:0] DRAM_DQ; // SDRAM Data bus 32 Bits
output [12:0] oDRAM0_A; // SDRAM0 Address bus 12 Bits
output [12:0] oDRAM1_A; // SDRAM1 Address bus 12 Bits
output oDRAM0_LDQM0; // SDRAM0 Low-byte Data Mask
output oDRAM1_LDQM0; // SDRAM1 Low-byte Data Mask
output oDRAM0_UDQM1; // SDRAM0 High-byte Data Mask
output oDRAM1_UDQM1; // SDRAM1 High-byte Data Mask
output oDRAM0_WE_N; // SDRAM0 Write Enable
output oDRAM1_WE_N; // SDRAM1 Write Enable
output oDRAM0_CAS_N; // SDRAM0 Column Address Strobe
output oDRAM1_CAS_N; // SDRAM1 Column Address Strobe
output oDRAM0_RAS_N; // SDRAM0 Row Address Strobe
output oDRAM1_RAS_N; // SDRAM1 Row Address Strobe
output oDRAM0_CS_N; // SDRAM0 Chip Select
output oDRAM1_CS_N; // SDRAM1 Chip Select
output [1:0] oDRAM0_BA; // SDRAM0 Bank Address
output [1:0] oDRAM1_BA; // SDRAM1 Bank Address
output oDRAM0_CLK; // SDRAM0 Clock
output oDRAM1_CLK; // SDRAM0 Clock
output oDRAM0_CKE; // SDRAM0 Clock Enable
output oDRAM1_CKE; // SDRAM1 Clock Enable
inout [14:0] FLASH_DQ; // FLASH Data bus 15 Bits (0 to 14)
inout FLASH_DQ15_AM1; // FLASH Data bus Bit 15 or Address A-1
output [21:0] oFLASH_A; // FLASH Address bus 22 Bits
output oFLASH_WE_N; // FLASH Write Enable
output oFLASH_RST_N; // FLASH Reset
output oFLASH_WP_N; // FLASH Write Protect /Programming Acceleration
input iFLASH_RY_N; // FLASH Ready/Busy output
output oFLASH_BYTE_N; // FLASH Byte/Word Mode Configuration
output oFLASH_OE_N; // FLASH Output Enable
output oFLASH_CE_N; // FLASH Chip Enable
assign oLCD_ON = 1'b1;
assign oLCD_BLON = 1'b1;
assign LCD_D = 8'hzz;
assign oFLASH_RST_N = 1'b1;
`define FLASH_WORD // use WORD mode of flash
`ifdef FLASH_WORD
wire FLASH_16BIT_IP_A0;
assign oFLASH_BYTE_N = 1'b1; // FLASH Word Mode Configuration
`else
assign oFLASH_BYTE_N = 1'b0; // FLASH Byte Mode Configuration
`endif
assign oFLASH_RST_N = 1'b1; // FLASH Reset
assign oFLASH_WP_N = 1'b1; // FLASH Write Protect /Programming Acceleration
assign oDRAM1_CLK = oDRAM0_CLK; //Fishy
wire CPU_CLK; //Fishy
NIOS2 the_NIOS2(
.clk (iCLK_50),
.pll_system (CPU_CLK),
.pll_memory (oDRAM0_CLK),
.reset_n (iKEY[0]),
.in_port_to_the_pio_button (iKEY),
.in_port_to_the_pio_switch (iSW),
.out_port_from_the_pio_LED_green (oLEDG),
.out_port_from_the_pio_LED_red (oLEDR),
.out_port_from_the_Hex0 (oHEX0_D),
.out_port_from_the_Hex1 (oHEX1_D),
.out_port_from_the_Hex2 (oHEX2_D),
.out_port_from_the_Hex3 (oHEX3_D),
.out_port_from_the_Hex4 (oHEX4_D),
.out_port_from_the_Hex5 (oHEX5_D),
.out_port_from_the_Hex6 (oHEX6_D),
.out_port_from_the_Hex7 (oHEX7_D),
.LCD_E_from_the_lcd (oLCD_EN),
.LCD_RS_from_the_lcd (oLCD_RS),
.LCD_RW_from_the_lcd (oLCD_RW),
.LCD_data_to_and_from_the_lcd (LCD_D),
.rxd_to_the_uart (iUART_RXD),
.txd_from_the_uart (oUART_TXD),
.zs_addr_from_the_sdram_1 (oDRAM0_A),
.zs_ba_from_the_sdram_1 (oDRAM0_BA),
.zs_cas_n_from_the_sdram_1 (oDRAM0_CAS_N),
.zs_cke_from_the_sdram_1 (oDRAM0_CKE),
.zs_cs_n_from_the_sdram_1 (oDRAM0_CS_N),
.zs_dq_to_and_from_the_sdram_1 (DRAM_DQ[15:0]),
.zs_dqm_from_the_sdram_1 ({oDRAM0_UDQM1,oDRAM0_LDQM0}),
.zs_ras_n_from_the_sdram_1 (oDRAM0_RAS_N),
.zs_we_n_from_the_sdram_1 (oDRAM0_WE_N),
.zs_addr_from_the_sdram_2 (oDRAM1_A),
.zs_ba_from_the_sdram_2 (oDRAM1_BA),
.zs_cas_n_from_the_sdram_2 (oDRAM1_CAS_N),
.zs_cke_from_the_sdram_2 (oDRAM1_CKE),
.zs_cs_n_from_the_sdram_2 (oDRAM1_CS_N),
.zs_dq_to_and_from_the_sdram_2 (DRAM_DQ[31:16]),
.zs_dqm_from_the_sdram_2 ({oDRAM1_UDQM1,oDRAM1_LDQM0}),
.zs_ras_n_from_the_sdram_2 (oDRAM1_RAS_N),
.zs_we_n_from_the_sdram_2 (oDRAM1_WE_N),
`ifdef FLASH_WORD
.tristate_bridge_address ({oFLASH_A[21:0],FLASH_16BIT_IP_A0}),
.tristate_bridge_data ({FLASH_DQ15_AM1,FLASH_DQ}),
`else
.tristate_bridge_address ({oFLASH_A[21:0],FLASH_DQ15_AM1}),
.tristate_bridge_data (FLASH_DQ[7:0]),
`endif
.read_n_to_the_cfi_flash (oFLASH_OE_N),
.select_n_to_the_cfi_flash (oFLASH_CE_N),
.write_n_to_the_cfi_flash (oFLASH_WE_N),
endmodule
can you guys find any error in writing....plus....can anyone tell me if my flash is working correctly???
also is my sdram working as i big 32mbx2 = 64mb memory???
