regarding config pins voltage levels
- 4 years ago
in case of doubt follow the Cyclone 10 LP Device Family Pin Connection Guidelines strictly.
If using a 3.3V PS configuration host, I would prefer to power the respective VCCIO with 3.3V, but 2.5V should work as well. In any case, the warnings about maximal FPGA input voltage should be observed and measures against possible overshoot of externally driven signals taken, e.g. source series termination.
There faults in your schematic snippet like 10k terminated MSEL2 pin.
Unused CLK inputs are flagged as GND+ in the pin list, means, they should be connected to ground or another signal. See also pib connection guidelines.Frank
Frank
