17 years agoRegarding an 8bit down counter
hi, i designed an 8bit down counter by referring the "advanced synthesis cookbook". but the RTL viewer is showing a MUX, an adder and an 8bit register to represent this counter. is this correct...
17 years ago --- Quote Start --- hi, i designed an 8bit down counter by referring the "advanced synthesis cookbook". but the RTL viewer is showing a MUX, an adder and an 8bit register to represent this counter. is this correct? should i not expect a counter block instead? implementing an adder for a counter does not make sense to me. Let me know your thoughts regarding this. thanks, Sumanth --- Quote End --- hi Sumath, how do you are the counter descript ? I assume you wrote something like this (Verilog) counter <= counter + 1 , that's you Adder Maybe you have defined a reset : if (reset) counter <= 0; else counter <= counter + 1 ; that's maybe the MUX Adder and Mux is ok for a counter.
