16 years agoreg timing analysis
hi, 1.is timing analysis compulsory for low speed fpga design(<2MHz). 2.my design is working properly, but in compilation report it is showing that timing requirements are not met. in such cas...
16 years ago --- Quote Start --- hi, 1.is timing analysis compulsory for low speed fpga design(<2MHz). 2.my design is working properly, but in compilation report it is showing that timing requirements are not met. in such case timing analysis is required? with regards --- Quote End --- Hi, can you post some of your timing violations here ? Which timing analyzer do you use ? Kind regards GPK
