9 years agoReference design (RapidIO) with errors ??
I have found the following reference design for RapidIO. https://www.altera.com/downloads/thank-you.html?swcode=www-ref-srio-6488 This reference can really help me because I was looking for a reference (for Linux actually, I don't know which OS fits for this refence , yet it can also help if it works). It seems that (maybe) there are missing files for this reference: I have found srio_main_full.c, but I can't find many symbols such as : TX_DATA_BASE, RX_DATA_BASE, and many more... I also find it strange to see that the DMA destination is 0 (?) according to these lines: //dest_buffer = (int *)RAPIDIO_IO_WRITE_SLAVE_BASE; dest_buffer = 0x00000000; I have also found a pdf explaining the reference design: https://www.altera.co.jp/content/dam/altera-www/global/ja_jp/pdfs/literature/an/an568.pdf Yet, I still don't understand how the dma operations here are responsible for rapidIO transaction: pkt_id = 0; ... IOWR_32DIRECT(STATS_BASE, 0, 0x00000010); // turn off shadow transfer in stats module IOWR_32DIRECT(DMA_WRITE_BASE, 24, 0x00010000); // bit 16 = soft_reset IOWR_32DIRECT(DMA_WRITE_BASE, 24, 0x00000000); // bit 16 = soft_reset IOWR_32DIRECT(DMA_READ_BASE, 24, 0x00010000); // bit 16 = soft_reset IOWR_32DIRECT(DMA_READ_BASE, 24, 0x00000000); // bit 16 = soft_reset ... // limit targeted address space to 2**16-1 target_address = (pkt_id & 0x0000ffff) * (payload); //printf("target address : %x \n", target_address); // setup the DMA write operation IOWR_32DIRECT(DMA_WRITE_BASE, 4, (int)tx_data); IOWR_32DIRECT(DMA_WRITE_BASE, 8, (int)target_address); IOWR_32DIRECT(DMA_WRITE_BASE, 12, payload); // page size length register in dma // not needed since enable_soft_burst is zero // IOWR_32DIRECT(DMA_WRITE_BASE, 16, payload/4); // stride in cycles // bit 0 is the continuous mode operation // bit 1 is enable_soft_burst // bit 2 is // bit 3 is the go bit IOWR_32DIRECT(DMA_WRITE_BASE, 24, 0x8); // go_bit=1, enable_soft_burst=0, continous mode=0 // setup the DMA read operation IOWR_32DIRECT(DMA_READ_BASE, 4, (int)target_address); IOWR_32DIRECT(DMA_READ_BASE, 8, (int)RX_DATA_BASE); IOWR_32DIRECT(DMA_READ_BASE, 12, payload); // wait for write dma to complete rdata = IORD_32DIRECT(DMA_WRITE_BASE, 0); wr_dma_done = (0x00000001 & rdata) == 0x00000001; //printf("waiting for write dma done \n"); while(!wr_dma_done){ rdata = IORD_32DIRECT(DMA_WRITE_BASE, 0); wr_dma_done = (0x00000001 & rdata) == 0x00000001; //printf("write dma base 0 %x \n", rdata); } //printf("write dma done \n"); // clear write done bit IOWR_32DIRECT(DMA_WRITE_BASE, 0, 0x0); Does anyone knows ? Thank you, RanNo RepliesBe the first to reply
