10 years agoReconfigure entire FPGA without using external pin
Hello all, i'm new in altera-forum and have problems with starting a reconfiguration process from inside a Cyclone 4-FPGA. The functionality i need is exactly the same as pulling the nconfig-pin l...
10 years agoGood morning,
Thanks a lot for your tips. On other FPGA-Boards we also use some reset-circuits. But because on the actual board the FPGA is master of the whole system the idea is to reset the device from internal logic without the use of external components. Perhaps i'm able to get the remote-update-core working properly, which seems to include the monostable-functionality you described. If there is no way to do this we would have to re-design our board and use some external circuits.
