12 years agoReconfigure after power on via EPCS64
Hi, I want to reconfigure and initialize a cyclone III from an EPCS64. I store the configuration in EPCS and then when the system is power on, I want to transfer configure file to the F...
12 years agoRefer to the configuration, design security, and remote system upgrades in the cyclone iii device family (http://www.altera.com/literature/hb/cyc3/cyc3_ciii51016.pdf) document.
To make your FPGA boot dircetly from an EPCS64 you need to connect it in Active Serial (AS) mode. Refer to the 'AS Configuration' section on page 9-12. Connecting it up in this way results in the FPGA controlling the configuration process. No need for any external controller. The type of file you need depends on how you intend to program the EPCS device. Refer to figure 9-30 on page 9-59. This shows the connections to the EPCS device along with JTAG connections to a header for programming. This allows you to program the FPGA (directly using the .sof file) or the EPCS64. To program the EPCS64 in this way you would create a .jic file which is discussed on page 9-21. Regards, Alex
