16 years agoReal Implementation
Hi, Say I have two architectures, A and B with A having complexity of 36 ANDs, 99 XORs. Meanwhile B having complexity of 37 ANDs, 105 XORs. The complexity here is derived directly from its arit...
16 years ago --- Quote Start --- I'm not sure of a good way to compare the two design types. You could probably estimate the gate count for an ASIC which would be similar to how I count the LE usage for small blocks of hardware in an FPGA. In an ASIC I would expect the XOR gate to be larger and slower due to the additional transistors required when compared to an AND gate. Oddly enough I have never implemented an ASIC so I might be oversimplifying things. Just like with FPGAs the sythesis tools may change the footprint to optimize for speed, area, and power. --- Quote End --- Thanks very much! Now I understand much better =)
