Jcole
2 years agoReading checksum of the rpd with FPGA
Would there be a method for the FPGA to verify the checksum of a .rpd file it receives serially? I'm passing a rpd file to my FPGA to write into Flash and I want to make sure that the data is proper...
NurAiman_M_Intel
2 years agoHi,
RPD is a bitstream which you can use write your own script to program into the flash. You cannot use Quartus Programmer to program RPD into flash. To validate the bistream, you can compare the data with the .map file. .map file can be generated during RPD file generating.
Aiman
Jcole
2 years agoHi, Thank you for responding, but that's not quite what I'm asking. I wanted to know if there was a checksum associated with the rpd file. I'm serially passing my FPGA the hex translation of a .rpd file from my connected processor. The FPGA will then write the received rpd file to the flash memory. I just want to know if there is a method for the FPGA to check that the file was received from the processor correctly such as the checksum.
- FvM2 years ago
Why not add a e.g. crc32 to the file?
