TSE and Optical Support
Dear Yi,
We have a working design using the TSE implemented within a 5CEFA7U19I7N that communicates to an external PHY. I wanted use a copy of this design to implement it with an external optical Phy \ Transceiver. When I went into the TSE I could not find anywhere within the instantiated TSE parameters to configure it to be used with an external Optical transceiver ?
Best regards
Shmuel
Hi Shmuel,
Wonder if you are referring to an optical module or external PHY outside the FPGA? actually it depends on the signal that communicates between the FPGA & external PHY, no specific parameter to select but need to select the correct ports and connect them to the target PHY.
- SDavi92 years ago
Dear Yi,
We are looking into a design using an external (from FBGA) optical transceiver !
Best regards
Shmuel
