TSE and Optical Support
TSE IP supports both MAC level MII/GMII/RGMII interface to PHY or serial interface/SGMII with PMA, so it may use with optical PHY as well, but just notice our TSE IP would have up to 1000Mbps ETH MAC.
Enclosed the block diagrams of TSE IP which may help:
- SDavi92 years ago
Dear Yi,
We have a working design using the TSE implemented within a 5CEFA7U19I7N that communicates to an external PHY. I wanted use a copy of this design to implement it with an external optical Phy \ Transceiver. When I went into the TSE I could not find anywhere within the instantiated TSE parameters to configure it to be used with an external Optical transceiver ?
Best regards
Shmuel
- Yi2 years ago
Hi Shmuel,
Wonder if you are referring to an optical module or external PHY outside the FPGA? actually it depends on the signal that communicates between the FPGA & external PHY, no specific parameter to select but need to select the correct ports and connect them to the target PHY.
- SDavi92 years ago
Dear Yi,
We are looking into a design using an external (from FBGA) optical transceiver !
Best regards
Shmuel
