The DC_FIFO issue of Cyclone 10 GX devices
May I know which Quartus version is being used? Please share a smaller version of your design to replicate the issue on our side. Simulatable design is preferred.
Parallely on your side, I would like to see the DC_FIFO ports in the signal tap. Please add as many signals at the FIFO level, including 'aclr' to the signal tap and send us a screen shot. Additionally add XCVR rx_ready signal as well.
I didn't quite understood what you mean by "we don't open 'aclr' port". Do you mean you never assert and de-assert the 'aclr' port? Please clarify.
Altera Tech Support
Also, let us know all the FIFO IP settings that you have used.
Altera Tech Support
- MinzhiWang1 month ago
Hi Ash,
Sorry for the delay of reply. Our FIFO parameters are all used default settings, except the ones of above block symbol indicating. They are 32-bit data width, and checking read-side and write-side ports of empty/full/usedw.
BTW, I tried your suggestion of checking aclr port, now the block symbol as following image. Then DCFIFO will work well by applying asynchronized clear control. But I don't know why this is necessary for it?
Best Regard
