MAX10 JTAG Secure Design Example unlock
Hi DB,
For Max 10 design example unlock, have you refer to the design example page and follow the instruction in the document?https://fpgacloud.intel.com/devstore/platform/15.0.0/Standard/max10-jtag-secure-unlock/
Let me know your concern.
Aiman
Hi @NurAiman_M_Intel ,
Thank you for response.
Yes, I followed the instructions in the document, and the design worked as described in the document, I was able to run JAM file in quartus_jli. I observed that FPGA reconfigured when JTAG was unlocked, and didn't reconfigured when JTAG is locked.
But then, after triggering unlock (by pressing pushbutton), in Quartus Programmer (connected to JTAG I/O) I couldn't program a new SOF file to CRAM nor new POF to on-chip flash. I couldn't erase on-chip flash as well untill the power cycle is performed on the board.
After power cycle, and triggering unlock command (PB), I was able to program SOF, POF and erase.
I run this exmaple on terasIC DE10-Lite, the simulation was performed before hardware run, because I didn't wat to lock the devboard permanently.
Thanks, and looking forward to hear from you
DB
