Investigation of HIGH-Level Voltage Fluctuations on MAX 10 3.3 V LVTTL Output Signals
some additional questions:
Are you seeing level variations in static voltage (DC or slow signal) or in high level of a pulse waveform (MHz speed)?
In the latter case, are you sure that it's no measurement artifact, e.g. due to unsuitable probing?
You say external device is DS90CR287, presume you are feeding CMOS inputs without additional load?
Regards Frank
- y-fujiwara1 month ago
1. The issue is a variation in the high-level voltage of a pulse signal in the 1 MHz range.
2. An active probe is used, with the GND connection made through the shortest possible via.
3. No additional load is applied.
We also confirmed with TI that noise from the LVDS signal may couple through the IC's internal circuitry.
Since this phenomenon has not been observed on signals connected to other devices, we believe this is the likely cause.
- AqidAyman_Altera1 month ago
May I know what is your main concern on this voltage fluctuations?
I checked the datasheet of the external device you connected and found that 2.8 V is still a valid high for the DS90CR287. The TxIN pins are LVTTL/LVCMOS inputs, and the datasheet specifies VIH at 2.0 V minimum (DS90CR287, SNLS056, https://www.ti.com/lit/ds/symlink/ds90cr287.pdf). Correct me if I'm wrong.
As you mentioned, this phenomenon does not affect the circuit's operation.
We investigated it as a precaution because we noticed an unusual feature in the waveform.
The phenomenon appears to be caused by internal noise coupling within the IC. Therefore, if there are no effective countermeasures available, we believe it should be acceptable to leave the design as it is.
