jaykrishna1's avatar
jaykrishna1
2 months ago
HSIO Differential Clock Output VOD and VOCM
Dear Intel Support Team, We are using the Agilex 5 FPGA A5ED065BB32AI4S in our design. We plan to use an HSIO differential clock output from the FPGA and connect this output to the differential clo...
  • Ash_R_Altera's avatar
    Ash_R_Altera
    2 months ago
    For the FPGA receiver, the key parameters are VID and VICM.
    From the schematic, the 10 kΩ/30 kΩ divider biases both inputs to approximately 0.75 × VIO_BANK0 (≈0.9 V for a 1.2 V bank), which falls within the documented True Differential Signaling receiver common-mode range. Therefore, the bias network itself appears compatible with the Agilex 5 HSIO receiver requirements. The remaining check is that the incoming differential clock meets the specified VID range and uses the recommended differential termination.
    Altera Tech Support
