Steve-Mowbray-ENL's avatar
Steve-Mowbray-ENL
6 months ago
How to tell Quartus my Arria10 target system CLKUSR frequency is 100MHz?
Timing analyser reports CLKUSR at 125MHz but target system has 100MHz on this pin to accommodate AS in combination with transceiver calibration as per the manuals -- there doesn't seem to be any cons...
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    5 months ago
    Hi Steve,
    Based on the response that I provided, you need not worry about the constraint on the pin for XCVRs.
    As the Quartus is assuming a 125MHz frequency, it is basically constraining it to the maximum allowed frequency for the XCVR applications. If the timing analyzer reports that 125MHz is achieved, then 100MHz will definitely work.
    Aqid
