How do I select an FPGA chip with a high-speed system clock available?
Hi songsong96,
this thread has been marked as inactive and will be transitioned to community support because there is no update received from you in a while.
If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread.
If you feel your support experience was less than a 9 or 10, please allow me to correct it before closing or please let me know the cause so that I may improve your future support experience.
Thank You.
Fakhrul
Hi Fakhrul
1. Is The fastest clock that can be made with ALTPLL is 40 pages of -c7 grade refers to the peripheral clock (155Mhz(b))? We receive a 40MHz clock from the outside and put it in ALTPLL INPUT. If I can use the clock of PLL OUT to 550 MHz(a), what am I missing?
What is The max of the fastest clock that I think can be made with ALTPLL is one of a, b, a, b, c, d, e?
2. I learned about ALTLVDS by looking carefully at the datasheet 46 page you showed me.
We asked because we wanted to control dac over 500 Msps. Can I control the 16-bit data bus at a high speed if I use ALTLVDS before that? According to DATASHEET, it was able to produce an OUTPUT of 400 MHz.
I'm looking for CYCLONE's LVDS EXAMPLE.
https://www.intel.com/content/www/us/en/docs/programmable/683520/22-1-20-0-1/design-examples.html
I found the link above, but I couldn't find the EXAMPLE FILE. I'm just downloading the PDF file and studying it.
Thanks to you, I'm learning a lot for you.
Songsong96
