10 years agore: clk gating in fpga design
hi, i have an rtl design which has a reference clock (100M) going into a verilog-coded divider module (to generate 50M and 25M clks) and then a verilog-coded clk-mux module (to select either 25M o...
10 years agohi all,
thanks for the inputs. after reading the replies, is my understanding correct that the actual clk_gate module will only be the one that leads to gated clocks in the design? and having a verilog coded clk divider or verilog coded clk mux module (which can be configured via registers) will not lead to gated clocks or will not harm the design in any way (like large skews)? is my understanding correct? or any type of logic on the clk route (be it a verilog coded divider or mux) will lead to a gated clock thus increasing the skew and hampering the design? i am putting together small design with dividers, mux etc. to check but in case someone can confirm the above, that would be great too ... thanks! z.
