I used the LPM_COUNTER out of the IP catalog I get together with Quartus Premium lite. Here I can't look into with the TCL viewer tool. This IP works fine at 400MHz.
But I need some arithmetic, so I started with Verilog. It is also easier to change the design editing some lines of code than drawing boxes and lines (block design).
Now it fails with 400MHz and I have to go down to 100Mhz.
After verification of the design, I split it into a counter/comparer part and an arithmetic part. Arithmetic is still Verilog, but for the counter and comparer I use the LPM_XXX IP blocks out of the library.
Now it works at 400MHz again.
I want to ask the community before I started this amount of work, to draw the schematic. It also could be, that it isn't faster than the Verilog design.
But now I can say and I know, that a simple counter, which is an adder and a register after the Verilog compiler is slower than the LPM_COUNTER library block.
And if you take a look at the old logic chips (74xxx) you will see, that a binary counter didn't use an adder to simply increment by one each clock cycle ...
With best regards
Gerhard
