Suresh430
1 month agoArria 10 SoC Dev Kit – Linux from SD Card Stops Booting After Erasing EPCQL1024
Hi Team, I am working with the Intel/Altera Arria 10 SoC FPGA Development Kit (10AS066). Please find the issue description in attached file and image. Thank you Suresh
Suresh430
29 days agoHi Kian,
Thanks a lot.
Currently EPCQL1024 not affected with the erase operation which i shared previously. After power-on board , seeing that Linux image is booting from SDcard, Hope contents are available in EPCQL1024. I want to know that ref .sof file from factory converted into .jic was programmed in EPCQL1024 right ?
Current below is the BSEL value.
AS-Active Serial(x1 and x4) means fpga configures from flash memory right ?
Where is the information about sdcard boot ?
Suresh
KianHinT_altera
14 days agoHi Suresh,
As there are no further inquiries, I will step back and allow the community to assist with any future follow-up questions.
Altera Technical Support
