13 years agoRandom results on FPGA
Hello, I'm using altera devices for about 10 years with quartus or quartus + synplify pro. I'm currently struggling for about a month !!! on this issue: Using the same netlist from synplify...
13 years ago --- Quote Start --- Hello, I'm using altera devices for about 10 years with quartus or quartus + synplify pro. I'm currently struggling for about a month !!! on this issue: Using the same netlist from synplify pro, the same timing constraints, and doing the place and route with quartus, I can get total different results on FPGA (stratix III): fully working, or failing on first HW accesses. The IP in the FPGA uses a lot of clock gating and I think that Quartus is not doing a good timing analysis (timequest reports no timing violations and the design is fully constrained), leading to such random results. Did you ever face such problem at your place ? Metastability report in timequest reports no problem. Resets are ok. Cooling the FPGA does not change anything. I never faced such situation before. I need help ! Alex --- Quote End --- Is it random per build or per download or per reset? If it is per build then what do you change to rebuild? If it is per download(of same one build) then it points to power up reset issues. If it is per reset(one download) then it is due to your reset. Try changing its duration. do you have multicycle deconstraint? if so double check them. Also check your clock signal and voltage levels.
