14 years agoQ:without epcs,why does not start uclinux
ssram,flash,etc WITHOUT EPCS!
quartus only has the avalon_cy7c1380_ssram IP core No avalon_cy7c1480_ssram IP core! so I wanna download the uclinux with loading in cfi_flash(PC28F00AM29EWL, 1Gb)and excuting in the ssram(72Mb,[B],so only 2M is recognized in SOPC or QSYS). (nios2-linux-2010)
make vendor_hwselect SYSPTF=/home/s4gt.ptf
RUNNING hwselect
--- Please select which CPU you wish to build the kernel against:
(1) cpu - Class: altera_nios2 Type: f Version: 7.08100
Selection: 1
--- Please select a device to execute kernel from:
(1) descriptor_memory
Class: altera_avalon_onchip_memory2
(2) ext_flash
Class: altera_avalon_cfi_flash
(3) onchip_ram_m9
(4) ssram
Class: no_legacy_module
Selection: 4
(4) ssram Class: no_legacy_module Size: 2097152 bytes -----------Means not recognizing the ssram IP to excute the uclinux correctly!!---------- make linux image ...then nios2-flash-programmer to the FLASH starting processor at reset vector nios2-terminal then there's no response ... Means not recognizing the ssram IP to excute the uclinux correctly!! fdsa1 Reply
(4) ssram Class: no_legacy_module Size: 2097152 bytes -----------Means not recognizing the ssram IP to excute the uclinux correctly!!---------- Quartus only has the avalon_cy7c1380_ssram IP core There's no avalon_cy7c1480_ssram IP core!
