lipingx
3 years agoqustion for ddr2 driver ALTMEMPHY
hello, I am not sure how to handle below warning. Whereever the clock pin is put, there is still such warning. I tried to put fpga clock input pin for any bank . Critical Warning (332049): Ignore...
AdzimZM_Altera
3 years agoHi,
The Quartus will ignore the constraint due to duplicate or not used sources.
Try to check if there any clock constraint has been made to DDR interface.
The DDR interface might generate it's own SDC file to constraint it's clock source.
Adzim
lipingx
3 years agocurrent clock solution, please help to check if such kind of clock for ddr pll_ref_clk has any problem or not?
-> external oscillator 25MHz -> FPGA PLL -> C0 (25MHz for overall fpga system) + C1(75MHz for DDR pll_ref_clk )
I also tried use external oscillator for connect to DDR pll_ref_clk directly.
Then everything goes fine, no warning. Please let me know what's reason.
