17 years agoQuestions regarding interfacing of & accessing custom hardware blocks
Hello, Firstly, before you read the rest - i'm pretty "green" with FPGAs, but i do know how to set up a Nios II soft-core processor system with IP blocks using the SOPC builder, and instantiating ...
17 years agoHi again,
Ok, the VHDL code has been completed, and decided to use the proposed form of interfacing with avalon as above, but some modifications, since i want to write to multiple input signals:
begin
process (clk)
begin
if clk'event and clk = '1' then
if reset_n = '0' then
readdata <= (others => '0');
else
if chipselect = '1' then -- our BCC is selected
if read = '1' then -- if the hardware wants to write to avalon (avalon should read from hardware)
if flag_bc = '1' then -- if a branch_cost is done
readdata <= "11111111111111111111111111111111";
readdata <= result;
elsif flag_bc = '0' then -- if branch cost is not done, just send 32 zeros
readdata <= "00000000000000000000000000000000";
end if;
end if;
elsif write = '1' then -- if write is asserted (avalon should write to the hardware)
case count is -- The order in which inputs are fed from C is fixed
when "000" =>
sys_rec <= writedata;
count <= "001";
when "001" =>
sys_ref <= writedata;
count <= "010";
when "010" =>
par1rec <= writedata;
count <= "011";
when "011" =>
par1ref <= writedata;
count <= "100";
when "100" =>
par2rec <= writedata;
count <= "101";
when "101" =>
par2ref <= writedata;
count <= "110";
when "110" =>
x <= writedata;
count <= "000";
end case;
end if;
end if;
end if;
end process;
With the following signals in the port declaration in the entity: signal clk,
reset_n,
read,
write,
chipselect : in std_logic;
signal readdata : out std_logic_vector(31 downto 0);
signal writedata : in std_logic_vector(31 downto 0)
); It seems to import in SOPC builder, with a warning: avalon_slave_0: signal readdata appears 8 times (only once is allowed). Also, the case conditional statement has been made so that i write from the C program, in a specific order, i.e. when it has received the first 32 bits, it assigns them to sys_rec, the next 32 bits are assigned to sys_ref and so on. flag_bc is a flag which is set in another process as soon as result is computed. When the flag is 0 i want the hardware accelerator to return 32 bits of zeros. When the flag is 1 i want it to send 32 bits of ones (to indicate that there is a result) and then afterwards give me the (32 bit) result. Would this actually work as it is supposed? I suppose i am reading from the register writedata, and sending to the register readdata. How do i know in which order they come? For example would readdata be at IORD(0x01001000,0) or would it be IORD(0x01001000,1) or something else... If the rest of the vhdl can help anything, i can post that also, but it needs to be shined up a bit.
