Question about PLL
Hello I have an Intel DE10-Lite board and i wanted to ask is there something else to do when creating the PLL to run on the device? Just to be clear not on testbench but on the device.
Yes that's all, assuming you've wired/instantiated it to the rest of your design correctly.
- NazrulNaim_Intel
As previously stated by user 'sstrell'. The reply can be accepted as the solution for the enquiry.
I will now set this case to close-pending.
Nazrul Naim
- antonto
Hello, thanks for your time.
I have already done that, so im assuming thats all enough to work?
Im sorry if these question are a bit sily but I dont have anyone to check my work so I dont know if what im doing is entirely correct.- sstrell
- sstrell
"Something else to do?" You need to add the PLL as an IP in your design from the IP Catalog in Quartus.
