12 years agoQuestion about optimizing a VHDL based system.
Hi all, I finally managed to have my system to work as I expected but I am quite dissapointed with the too high number of LEs required by the entire project. I wanted to know if you had ...
11 years agoHi,
I've decided to reduce the bus sizes and I've managed to double the depth of my pipeline. I also want to put the largest registers in RAM but I don't really know how to do it. I've found the following doc : http://quartushelp.altera.com/12.1/mergedprojects/hdl/vhdl/vhdl_file_dir_ram.htm I followed the procedure like this : -- First, declare a signal that represents a RAM type memory_t is array (0 to 15) of std_logic_vector(31 downto 0); signal my_ram : memory_t; attribute ramstyle : string; attribute ramstyle of my_ram : signal is "M9K"; But in the Fitter report it says that 0 M9K out of 66 have been used. Did I miss something ? Cheers,
