15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years ago --- Quote Start --- Will I have to write some test programs or modify any generated codes to simulate my design [writing data to the RAM]. --- Quote End --- Yes. You will have to generate Avalon-MM BFM transactions to write to an address that corresponds first to the PCIe master interface so that a PCIe write transaction is generated, that write transaction should then be accepted by the target interface on the second design (BAR0 access), and then that should translate to an Avalon-MM transaction to your RAM internal to the second design. --- Quote Start --- Is this an hierarchy system design example? [first you create a PCIe BFM, and then save that system and then connect that system to the RAM (second system)] --- Quote End --- There is no hierarchy here; they are two completely separate designs (two separately named Qsys designs). A hierarchical design is one in which you define a Qsys component as a collection of Avalon components, and leave top-level Avalon connections, so that the new component can be dropped into an Avalon system. The components you are to design have PCIe ports at the top-level. You will connect them in the testbench, but you would not use these components in a Qsys hierarchy. --- Quote Start --- I am curious, how long have you been working with Quartus you have a good working knowledge about it. [I started 3 weeks ago] --- Quote End --- Quite a few years. Cheers, Dave
