10 years agoQuestion about Clock Enable port on D flip flop
I am using clock enable signal to synchronize my VHDL design with an external software. Here is how one of the flipflops look like in RTL viewer http://www.alteraforum.com/forum/attachment.php?att...
10 years agoOkay. get it.
But i still tend for : even control signals changed witch clock with the same frequency as data clock. does phase shift possible between these two clocks to improve hold time or it doesn't need??? for example when you try use control signal with 180 degree phase shift <- you might get setup violation. I ask cause ICG (iternal clock gate) is generated per LAB at this labclkena signal. and I feel weak analysis for the topic. Frequency Contol signal clock = Frequency data signal, Control signal clock has phase shift to data signal clock.
